Poll
Overall performance for 2010.  Consider timetable, congestion, parking, stations, and bus integration.
4 or less
2 (33.3%)
5
2 (33.3%)
6
2 (33.3%)
7
8
9
10
Total Members Voted: 4
Author Topic: Rosewood  (Read 3968 times)
Offline ozbob
Rosewood
« on: November 28, 2010, 07:04:31 AM »
Have your say!
Offline ozbob
Re: Rosewood
« Reply #1 on: November 28, 2010, 07:01:52 PM »
After constantly pushing for a number of years a small victory in 2010, the peak gap was reduced --> http://railbotforum.org/mbs/index.php?topic=3747.msg25648#msg25648
Rosewood services are essential and will increase as the new developments proceed (already started).
Shuttles are working fine, thru is better but it does mean services where there may not be.   Stations will need upgrades.  One way of establishing commuter rail to Gatton - Helidon would be electric-hybrid sets.  Run under wires to Rosewood then battery/diesel.  These units exist.
  • Guest
Re: Rosewood
« Reply #2 on: November 28, 2010, 08:41:25 PM »
I don't follow what you mean by this.
Offline ozbob
Re: Rosewood
« Reply #3 on: November 29, 2010, 03:07:44 AM »
It means a local crew can provide services during the day, where as if it was all thru there would be a greater requirement overall for trains and crew. They do it for a reason.
  • Guest
Re: Rosewood
« Reply #4 on: November 29, 2010, 09:01:15 AM »
Doesn't sound like much of a reason to me.  An hourly shuttle uses up just as much of the crews time as half hourly through running in theory, although the extra time at the controls may mean that rest breaks need to be taken sooner.
Might I suggest that the major reason is to improve on time running on the Ipswich Line?
Offline ozbob
Re: Rosewood
« Reply #5 on: December 16, 2010, 05:34:57 PM »
Score 5.0
Offline petey3801
Re: Rosewood
« Reply #6 on: January 01, 2011, 05:16:28 PM »
One 3-car set is currently utilised for the shuttle service with one crew. A half-hourly frequency to Rosewood would require a second set and second crew. Also, there are not many crews outside Ipswich depot that are qualified for Rosewood.
  • Guest
Re: Rosewood
« Reply #7 on: January 01, 2011, 08:36:53 PM »
It requires more than one crew, but with through running it would only require part of a second crew.  I.e. a second crew for only 20 minutes or so of every hour in addition to current.  I feel that it would be worth trying to see if patronage from beyond Rosewood increases.  Australians seem to really hate transferring!
It is a good point about the crew qualifications though.  I'm sure if there was more through running, crews from Mayne and Caboolture would need to be qualified for Rosewood.
Offline Mozz
Re: Rosewood
« Reply #8 on: January 01, 2011, 09:04:19 PM »
I believe the root cause issue with transferring is that frequency is generally poor so in commuters minds: transfer = significant delay = dislike of transfers
If frequency is high then: transferr = acceptable delay = acceptance of transfer
  • Guest
Re: Rosewood
« Reply #9 on: January 01, 2011, 09:16:22 PM »
Yes, I think there is a lot of truth to that.
Offline Arnz
Re: Rosewood
« Reply #10 on: January 01, 2011, 09:35:53 PM »
Don't forget 'Zero-Harm' basically means that any 6-car trains that operates past Ipswich in revenue service is basically a "3-car" set with the back 3 turned off.
IMO, an ideal (fantasy file  ::)) arrangement would be either a 3-car set (or a 4-car ICE set) operating limited exp/stops into the City (provided paths and stopping arrangements are ideal).  Otherwise on a more realistic note, a more frequent peak shuttle (every 15 mins) may have to suffice.
Any thought of running ICEs past Ipswich for limited expresses would require training for Ipswich crews (ICE crews are based only at 3 depots; Mayne, Caboolture and Nambour).
« Last Edit: January 01, 2011, 09:45:36 PM by Arnz »
Offline #Metro
Re: Rosewood
« Reply #11 on: January 01, 2011, 10:13:23 PM »
Yes.
It isn't transferring that is the problem- entire cities' transit systems are built on the principle. There are fast transfers and slow transfers. There are transfers where you walk across a platform inside a nice station, and there are transfers where you have to walk out of a building, down a flight of stairs, cross a road in the pouring rain and then wait for the next service.
Its the wait, and the difficulty in doing it. Poor information, mapping and marketing does not help either.
Offline petey3801
Re: Rosewood
« Reply #12 on: January 02, 2011, 11:00:12 AM »
I'll rephrase that, it requires one crew at a time, there are numerous jobs at Ipswich which involve two, three or four (and up to seven) Rosewood shuttle runs in a shift.
As for transfer, in the Rosewood shuttle case, it shouldn't be much of a problem due to the shuttle and Ipswich trains being a'Guaranteed' connection (on most runs). This often actually causes the Rosewood shuttle to become unreliable due to the Ipswich trains running late into Ipswich and holding up the shuttle. Generally there is enough time at Rosewood to pick up most of the lost time, however there are some cases (especially in peak) where the time is unable to be picked up again for quite a few runs due to very tight turnarounds at both ends.
  • Guest
Re: Rosewood
« Reply #13 on: January 02, 2011, 02:01:17 PM »
I understood what you meant.  The point I was trying to make is that with through running you wouldn't have to have the second crew full time west of East Ipswich.  Although the new timetable squeezes the turn times, so that fruit cannot be picked for the through running half hourly plan.
I also don't understand why the first services of the day are to be done with shuttles from Rosewood rather than through running services as in the current timetable.
I hope I've made that clear.
Offline petey3801
Re: Rosewood
« Reply #14 on: January 02, 2011, 02:11:45 PM »
Current turnaround times are only 12 minutes at Ipswich, so to have through running instead of the shuttle would require at least another crew for another train to have through running, if that makes sense. In other words, for the purpose of reducing the crewing needs, it's pointless, as another train would have to be run to keep the half hour frequency on the Ipswich line.
I'm with you on this one, I have no idea why they decided to do that in the new timetable. If they added an extra one or two early morning services from Ipswich which connect with the shuttle service I could partially understand (but, once again, if they did that they might as well just run the service from Rosewood in the first place instead of having the shuttle going...), but the first service from Ipswich still won't arrive into Brisbane until after 05:30 which is an absolute joke!
Offline Arnz
Re: Rosewood
« Reply #15 on: January 02, 2011, 02:39:26 PM »
It would cost quite a fair bit of money for a second guard to hop on at Ipswich just to shut off the back 3 cars and man the back 3 cars, due to 'Zero Harm' requirements for short platforms west of Ipswich.
Not to mention switching units at Rosewood, and then turning the back 3 cars on again on arrival at Ipswich.
  • Guest
Re: Rosewood
« Reply #16 on: January 02, 2011, 03:28:08 PM »
Yes, zero charm doesn't make any sense!  Not sure about the problem with switching units though.  Isn't Rosewood a 6 car platform?  It's just like every other end swap when the terminating and starting services both have the rear 3 cars locked.  Unless you can tell me that this never happens (possible).  Even if it doesn't happen currently, I don't see the problem with doing it here.
Offline petey3801
Re: Rosewood
« Reply #17 on: January 02, 2011, 03:30:59 PM »
No second guard needed. Current procedure (for through trains from Brisbane) is front 3-cars are emptied out at Ipswich (utilising the guard and station officer) with all through passengers put into rear 3-cars.
Train then runs to Rosewood with rear 3-cars on the platforms to Rosewood. Once at Rosewood, driver changes ends and the (now) front 3-cars are used with the front 3-cars stopped on the platforms to Ipswich, from where normal operation continues. The main reason the rear 3-cars are used from Ipswich to Rosewood (which become the front 3 on the return) is so the level crossings at Karrabin and Thagoona are not blocked by the stopped train.
The current through Rosewood train late at night is the exception to this, as it uses the front three cars due to the rear 3-car unit being locked from Caboolture.
  • Guest
Re: Rosewood
« Reply #18 on: January 02, 2011, 03:33:43 PM »
Does the current late night train just block the level crossings?
Thanks for that info, at least zero charm isn't as stupid as people have said.  I always expected thus.  Assuming you are correct of course.
Offline petey3801
Re: Rosewood
« Reply #19 on: January 02, 2011, 03:34:48 PM »
Platform 2 (Down) at Rosewood is a 3-car (with a bit of overlap at each end) platform. Platform 1 (Up - rarely used) is a 5-car platform. The reason for the use of Platform 2 instead of 1 is due to the ticketing and toilet facilities being on Platform 2, which is also where the bus stop is. Also, platform 2 is much easier accessed by disabled passengers as opposed to platform 1.
Offline petey3801
Re: Rosewood
« Reply #20 on: January 02, 2011, 04:10:03 PM »
Yes, late night train blocks the level crossings, but at that time of night there simply aren't many cars out there to be inconvenienced. That, and the train isn't stopped for long at either Karrabin or Thagoona most nights.
I should hopefully know the drill, considering i've driven said services numerous times  ;)
  • Guest
Re: Rosewood
« Reply #21 on: January 02, 2011, 04:11:28 PM »
Thanks for the correction!  Seems I'd been given wrong info.  Maybe lengthen platform 2 to 6 car length.
