New timetables - out of the square!
Started by ozbob, January 21, 2010, 13:51:46 PM
Your suggestions please.
Cross conecting services,
Clevland to Ipswich, via Dutton Park - Yeeroongpilly - Corinda
Gold Coast to CBD/Airport via Moorooka - Sherwood - Indoorpilly - Toowong - Roma Street
Rerouting some Gold Coast - Airport services would
(a) provide direct access to gold coast passengers to Indoorpilly and Toowong, there is ample capacity on the main between Sherwood and the CBD, would provide a more direct access to all Ipswich/Springfield line stations and release train paths through the South Brisbane - Bowen Hills bottle neck.
(b) provide direct access to Airport Services for pasengers from Sherwood - Indoorpilly and Toowong that presently does not exist without increasing the numbers of services by better utilisation of equipment and existing infrastructure.
It is worth a small trial.
If freeways are full and they don't even go to the city, it might work for rail...
#3
Convert the Ferny Grove and Doomben lines to light rail.  Extend Doomben light rail into the new developments at Hamilton.  From Bowen Hills track the light rail through Exhibition, Normanby, to Roma St, then up George St to Parliament.  Extend the light rail into the Samford Valley from Ferny Grove.
http://www.railway-technology.com/projects/madrid-light-rail/images/1-madrid-light-rail.jpg
:-w
Quote from: mufreight on January 22, 2010, 04:16:11 AM
So you would be reducing the number of trains from Gold Coast to South Bank, and South Bank to Airport, and be creating a more complex timetable with 2 Gold Coast routes (with added conflicting moves)? Are people from Sherwood not capable of changing trains at Central?
Quote from: ozbob on January 22, 2010, 19:28:21 PM
:-w
I doubt light rail would have enough capacity for projected passenger movements on the Ferny Grove Line.
Doomben may be a possibility though if space is available at Eagle Junction for an interchange.
Sunday excursion trains.  Ipswich to Gold Coast via Tennyson.
albiwan
Excursion trains! I Interesting... how about Eumundi/ Yandina markets service on a Saturday.  Morning service Roma St- terminate Cooroy return Nambour as shuttle only. Mid morning and/or 1-2 pm shuttle Nambour - Cooroy-Nambour.
#7
QuoteExtend Doomben light rail into the new developments at Hamilton.
I like this idea.
Freight trains also use that alignment IIRC, re-wiring and heavy rail compatibility...
A light rail vehicle would likely be ...
... a tram-train.
And while it is going near the busway, it could probably be put on the busway too.
#8
Check out this here!
They could run out to Doomben on the existing heavy rail then light rail to Hamilton ...
more http://en.wikipedia.org/wiki/Alstom_Citadis
Connect 1 tph Gold Coast to Sunshine Coast and 1tph to Doomben, then connect Airport to Manly/Cleveland.
2tph Doomben (or Eagle Farm, or Hamilton North Shore) to Corinda (or Darra, or even Richlands) via South Brisbane & Tennyson.
Quote from: colinw on August 09, 2010, 21:29:15 PM
That one would be better off coming from Ferny Grove, unless these trains are different trains to the ones which will increase frequency on the inner Beenleigh line.
