Planned closures - discussion
Started by ozbob, November 16, 2009, 19:14:34 PM
Quote from: Happy Bus User on August 07, 2011, 09:45:49 AM
That is rather confusing, it says " all trains between Dutton Park and Varsity Lakes will be replaced by buses in both directions". Too bad if you lived at Varsity Lakes and didn't realise that the bus bit doesn't apply to you  ;)
Yes, the key part of that sentence was the little add on "at most locations". While Varsity Lakes might not be as bad as there are 3 bus routes between VL and Robina and its the end of the line, its the stations in the middle that I think are shockers. It seems you need to pretty much do a round trip via the city to get onto a bus to take you south, or to any other train station on the Beenleigh/GC lines.
ClintonL94
http://translink.com.au/travel-information/service-updates/bulletin/1311917604
Goodfellows Road, Murrumba Downs bus stop change
From Monday 8 August, the bus stop on Goodfellows Road, on the far side of Braidwood Avenue, will be relocated:
Bus stop closed: Goodfellows Road (farside Braidwood Avenue).
Temporary bus stop: Goodfellows Road (farside Goodwood Road).
Map of Goodfellows Road, Murrumba Downs bus stop change.
We appreciate your patience.
Affected Services:
ClintonL94
http://translink.com.au/travel-information/service-updates/bulletin/1312865013
Merritt Street, Capalaba bus stop closure
Until further notice, the bus stop on Redland Bay Road (approaching Merritt Street) will be closed due to Energex works.
Alternative stops are available at either Smith Street or Andrew Street.
Closed bus stop: Merritt Street, Redland Bay Rd App Merritt St
Alternative bus stops:
  • Smith Street, Redland Bay Rd App Smith St
  • Andrew Street, Redland Bay Rd Opp App Andrew St
Map of temporary bus stop closure on Redland Bay Road
We thank you for your patience.
Affected Services:
ClintonL94
http://translink.com.au/travel-information/service-updates/bulletin/1312957153
David Low Way, Marcus Beach temporary stop change
From Tuesday 9 August to Tuesday 23 August, temporary bus stop closures will be in place at the northern intersection of David Low Way and Mahogany Drive, Marcus Beach due to maintenance work.
Alternative stops are near the roundabout at the southern intersection of David Low Way and Mahogany Drive (near Melaleuca Street).
Closed bus stops:
  • David Low Way (approaching Mahogany Drive), Marcus Beach
  • David Low Way (opposite, approaching Mahogany Drive), Marcus Beach
Alternative bus stop:
  • David Low Way (farside Mahogany Drive), Marcus Beach
  • David Low Way (farside Melaleuca Street), Marcus Beach
Map of temporary closure on David Low Way at Marcus Becah.
Affected Services:
ClintonL94
http://translink.com.au/travel-information/service-updates/bulletin/1312768206
Bowen Hills to Ferny Grove track closure
From 7.30pm Friday 16 September until the last train on Sunday 18 September, tracks between Bowen Hills and Ferny Grove will be closed for maintenance and upgrade work.
During this time, buses will replace trains in both directions. Remember to plan your journey well in advance as delays of up to 60 minutes are expected.
Trains will return to normal on Monday 19 September.
Improvement works will include:
  • track duplication works between Keperra and Ferny Grove
  • reconditioning of Alderley station platforms
  • removal and replacement of rails at Newmarket station
  • overhead works
  • various maintenance between Bowen Hills and Ferny Grove.
Customers with a disability can call 07 3606 5555, or SMS 0428 774 636, for assistance.
We appreciate your patience as upgrade and maintenance works continue across the network.
Affected Services:
  • Ferny Grove line
ClintonL94
http://translink.com.au/travel-information/service-updates/bulletin/1312327875
Northgate to Gympie North track closure
From the first service (2am) on Saturday 10 September to the last service (11.59pm) on Sunday 11 September, tracks between Northgate and Gympie North will be closed for maintenance and upgrade work.
During this time, buses will replace trains, servicing all stations in both directions. Trains will return to normal on Monday 12 September.
  • remove and replace rails at Bald Hills
  • station upgrade works at Narangba
  • points improvement works at Palmwoods
  • various other preventative and corrective maintenance between Northgate and Gympie North.
Please note:
  • Bilsen Road, Geebung (Sunshine train station) and Telegraph Road, Bald Hills level crossings will be unavailable for pedestrian and vehicular traffic due to maintenance work.
Train replacement bus stops will be located in close proximity to all stations, but you should take particular note of the following:
  • Sunshine station - train replacement bus stop will be located on the corner of Pritchard Road and Bilsen Road.
  • Bald Hills station - train replacement bus stop will be located on the corner of Lucy Street and Cullimore Street.
  • Zillmere station - train replacement bus stop will be located on Hanford Road (Zillmere Road end), station side, outside the shoe repair store.
  • Strathpine station - train replacement bus stop will be located in Station Street opposite the Strathpine library.
If you're heading to the Brisbane Broncos v New Zealand Warriors qualifying final on Saturday 10 September or to the Bridge to Brisbane on Sunday 11 September, make sure you plan your journey well in advance as delays can be expected.
Stations affected by the track closure
Affected Services:
  • Caboolture line
  • Sunshine Coast line
ClintonL94
http://translink.com.au/travel-information/service-updates/bulletin/1315874305
Northgate to Shorncliffe track closure
From the first train on Saturday 1 October until the last train on Sunday 2 October, tracks between Northgate and Shorncliffe will be closed for maintenance and upgrade work.
During this time, buses will replace trains in both directions. Remember to plan your journey in advance as delays of up to 60 minutes are expected.
Train services will return to normal on Monday 3 October.
  • overhead works
  • foliage trimming
  • track inspections between Northgate and Shorncliffe
  • station works at Sandgate station
  • various maintenance between Northgate and Shorncliffe.
Customers with a disability can call 3606 5555, or SMS 0428 774 636, for assistance.
Affected Services:
  • Shorncliffe line
ClintonL94
http://translink.com.au/travel-information/service-updates/bulletin/1315962137
Roma Street to Corinda & Dutton Park track closure
From 7pm until the last train on Sunday 23 October, tracks between Roma Street and Corinda, and Roma Street and Dutton Park stations, will be closed for maintenance and upgrade works.
During this time, buses will replace trains in both directions. Remember to plan your journey in advance as delays of up to 30 minutes may be experienced.
Trains will return to normal on Monday 24 October.
  • station works at South Brisbane
  • overhead works
  • various maintenance works between Roma Street and Corinda, and Roma Street and Dutton Park.
We thank you for your patience as upgrade and maintenance works continue across the network.
Affected Services:
  • Beenleigh line
  • Cleveland line
  • Gold Coast line
  • Ipswich Rosewood line
  • Richlands line
ClintonL94
#88
http://translink.com.au/travel-information/service-updates/bulletin/1315891840
Dutton Park to Varsity Lakes track closure
From the first train on Saturday 29 October until the last train on Sunday 30 October, tracks between Dutton Park and Varsity Lakes stations will be closed for maintenance and upgrade work.
Trains will return to normal on Monday 31 October.
  • overhead works at Beenleigh station
  • track and drainage works
  • vegetation maintenance.
Customers with a disability can call 3636 5555, or SMS 0428 774 626, for assistance.
Affected Services:
  • Beenleigh line
  • Gold Coast line
ClintonL94
http://translink.com.au/travel-information/service-updates/bulletin/1315877813
From 7pm until the last train on Sunday 9 October, tracks between Roma Street and Corinda, and Roma Street and Dutton Park stations, will be closed for maintenance and upgrade works.
During this time, buses will replace trains in both directions. Remember to plan your journey well in advance as delays of up to 30 minutes are expected.
Train services will return to normal on Monday 10 October.
  • overhead works
  • various maintenance between Roma Street and Corinda and Dutton Park stations.
Customers with a disability can call 3606 5555, or SMS 0428 774 656, for assistance.
Affected Services:
  • Beenleigh line
  • Cleveland line
  • Gold Coast line
  • Richlands line
ClintonL94
http://translink.com.au/travel-information/service-updates/bulletin/1316146082
From 9pm until to the last train on Monday 31 October, tracks between Roma Street and Corinda, and Roma Street and Dutton Park stations, will be closed for maintenance and upgrade works.
Trains will return to normal on Tuesday 1 November.
Improvements works will include:
  • overhead powerline works
  • various maintenance works between Roma Street and Corinda and Dutton Park.
Customers with a disability can call 3306 5555, or SMS 0428 774 636, for assistance.
We thank you for your patience as maintenance works continue across the network.
Affected Services:
  • Beenleigh line
  • Cleveland line
  • Gold Coast line
  • Richlands line
ClintonL94
http://translink.com.au/about-translink/what-we-do/infrastructure-projects/south-brisbane-station-upgrade
South Brisbane station upgrade
WhereSouth Brisbane station
Station closure31 October - 9 December 2011
ContactPhone: 1800 525 863
Email: stationupgrades@qr.com.au
What is the South Brisbane station upgrade project?
Queensland Rail, in partnership with TransLink, is delivering the City Network Station Upgrade Program to improve station facilities across 50 stations within the City network. The South Brisbane station upgrade is part of a joint Queensland Rail and TransLink initiative to improve and restore the heritage-listed station and improve access and facilities for our customers.
South Brisbane station is an important hub in South East Queensland's rail network and provides an important station for regular commuters and those visiting Brisbane's cultural precinct.
Built in 1891, the station has significant historic value and is listed on the State Heritage Register.
If you'd like to learn more about the South Brisbane station upgrade, please visit Queensland Rail's project webpage.
Station closure - 31 October to 9 December 2011
Due to the extent of the construction works that will be undertaken, which includes structural maintenance and platform raising, the station must be closed to ensure everyone's safety.
By closing the station, we can deliver important key improvements to the station in time for the busy holiday period.
Train services will still be able to pass through the station, but will not be stopping at the platform.
Alternative transport
The station closure will only affect customers wanting to get on or off at South Brisbane station, not those travelling through the station.
If you want to go to South Brisbane station you can either:
catch your normal train service and touch off at South Bank station, then connect to Queensland Rail's complementary shuttle bus service to South Brisbane station
catch your normal train service and touch off at Roma Street station, then catch a bus from Roma Street busway station platform 2 to Cultural Centre busway station (a short walk from South Brisbane station).
Please remember to always touch on and touch off when you start and finish your journey.
More information on go card and the transfer rules.
For more information on planning your journey, please use the journey planner.
What will the station upgrade involve?
The South Brisbane station upgrade will restore and preserve the heritage-listed building, improve station access for people with a disability, and enhance customer facilities.
Improvements to station access will include:
  • a new accessible ticket office window
  • raising the height of platform one
  • a new accessible toilet.
General station improvements will include:
  • new electronic passenger information display screens
  • additional CCTV security
  • refurbishment of existing toilets
  • refurbishment of the subway with energy efficient lighting, new cladding, floor and ceiling finishes.
Improvements to preserve the heritage-listed building will include:
  • paint removal and restoration of the masonry and facade of the building
  • restoration of heritage furniture, fascias and awnings.
We appreciate your patience during the station closure.
ClintonL94
http://translink.com.au/travel-information/service-updates/bulletin/1315887139
Corinda to Rosewood track closure
From 8pm Friday 14 October until the last train on Sunday 16 October, tracks between Corinda and Rosewood stations will be closed due to maintenance and upgrade works.
Trains will return to normal on Monday 17 October.
  • track maintenance works between Walloon to Thagoona
  • stabling yard works at Redbank
  • track work at Thagoona
  • station renovation works at Corinda
  • overhead power line works
  • various maintenance between Corinda and Rosewood (including Richlands).
Customers with a disability can call 3606 5555, or SMS 0428 774 636 for assistance.
Route 539 Rosewood to Helidon railbus
Customers travelling on the 539 Rosewood to Helidon railbus may expect delays of up to 15 minutes during this track clousure period.
Railbus services affected include:
  • Friday 14 October - 8.05pm service
  • Saturday 15 October - 8.03am, 12.03pm, 5.01pm and 7.03pm services
  • Sunday 16 October - 8.33am, 12.06 pm and 7.06pm services.
Affected Services:
  • Richlands line
Am becoming busy as heck as I head into my final assessment weeks.  But quickly, I was caught up in that closure on the Ipswich line last weekend and after arriving in Ipswich to transfer onto a rail replacement bus there was one driver/co-ordinator ordering (confused) people to touch on at the fare gates at Ipswich station.  The gates were barricaded off so if you had to touch off after been told to touch on elsewhere, that would've been impossible to do so.  At some of the other stations you could not access the platforms to touch off, they were taped off with workers doing what they do.  I ended up staying away from him as he was blocking people from boarding the bus before they had touched on, I wandered down to another bus and he just let me on with no problems.
I thought that the rule was with rail replacement the trip was complementary and you did not have to touch on/purchase a ticket until you got to the destination from where the trains were departing from.  Can anyone confirm this?
It wouldn't surprise me if there were a number of fixed fares happening that day.
I can see some problems.  Traditionally no one has really bothered with tickets on rail replacement, although officially tickets are required.  With go cards, often it is not possible to access the gear on rail stations because they are closed off from public access for works etc.  Also the stops may be a way from the stations as well.  Until go gear is on the buses, it is really awkward to be changing the normal practises as folks get rattled and end up with fixed fares.
How would a bus driver at Corinda know if anyone has touched on??  Hysterical .....
Also, fixed fares are NOT counted as a journey.  So this further complicates the free travel after 10 journeys as folks could be caught short as they are anticipating that their journey number 10 will give them free travel later in the day.  If journey 10 is a fixed fare then oh dear.
My own personal view and practise has been to board the bus with my go card ready to touch on (as per the translink official go card guide).  If there is no go gear, the driver just waves you on is my experience.  If I am not travelling by train then I don't touch on a railway station (as per the guide).  If TransLink want to change that then they need to be explicit in their instructions, or ensure buses have the go gear.
Ozbob's Gallery Forum   Facebook  Twitter  Mastodon - aus.social
Sydney has the same ridiculousness.  Rail replacement buses theoretically require you to have a valid ticket, and this is stated often but never enforced.  Bizarre.
#96
As far as I am concerned, it is touch on and off when leaving stations.  Period.
Rail replacement buses will NEVER accept go cards, even if they are supplied by a TransLink contract operator with the equipment fitted in their fleet, such as Thompsons or Kangaroo.  Rail replacement services are not programmed in and the main objective is in moving people quickly around the disruption.
TransLink should legitimise this practice.
It does seem a bit confused. The last closure on the FG line I got caught up in, I was heading outbound and I'm pretty sure the guard told everyone to touch off at Bowen Hills. Which is certainly what everyone was doing.
Closure Sunday night Roma St-Dutton Park.
Still no info about the effect on the Cleveland line.  Will it start at Buranda?  In Sydney, they'd probably ask you to use the 111 or other bus to get there.
Quote from: Simon on October 20, 2011, 16:16:28 PM
Dutton Park. Whenever these closures happen, the Cleveland line will always start at Dutton Park (turnback reasons).
Last time this closure was on a couple weeks back, they had Beenleigh trains continuing to Cleveland and vice versa (BNH-CVN, CVN-BNH).
Quote from: SurfRail on October 18, 2011, 13:21:24 PM
The problem comes though is if the station is cordoned off from the public as Ipswich and Dinmore (I think from memory) was that day.  How does one touch off at that station if you can't get to it?  I'm certainly not going to wait 10 working days to get my money back from a fixed fare simply because I can't touch off at a station due to scheduled trackwork/station work.
To me, from a customer perspective, trackwork is seen as an inconvenience (although necessary).  Why should it not be simply that during trackwork days, passengers get free rail replacement bus travel and then just for them to pay the trip in once they get onto a train?
Quote from: STB on October 20, 2011, 22:49:08 PM
Talking more about where you are able to commence a rail journey, which is then interrupted.  If the entire Ipswich line was shut down from Roma Street and I was starting at say Redbank, I would not expect to pay any fare.  However, if the line was shut down from Darra to the City only, I would be touching off at Darra.  I doubt that you would ever be unable to touch on or touch off in this situation because you are getting off at an operational station.
Sometimes the power is cut to certain stations during the day too (Depending on what their doing).
ClintonL94
http://translink.com.au/travel-information/service-updates/bulletin/1319007116
Dutton Park to Cleveland track closure
From the first train on Saturday 12 November until the last train on Sunday 13 November, tracks between Dutton Park and Cleveland stations will be closed for maintenance and upgrade work. Please note that Dutton Park station is on the Beenleigh line.
During this time, buses will replace trains in both directions. Remember to plan your journey well in advance as delays of up 60 minutes are expected.
Trains will return to normal on Monday 14 November.
Improvement works include:
  • track works between Manly and Birkdale
  • station renovation works at Wynnum North
  • various maintenance works between Dutton Park and Cleveland.
Customers with a disability can call 3606 5555 or text 0428 774 636 for assistance.
Affected Services:
  • Beenleigh line
  • Cleveland line
  • Gold Coast line
ClintonL94
http://translink.com.au/travel-information/service-updates/bulletin/1319008692
Sherwood to Rosewood track closure
From 8pm Friday 18 November until the last train on Sunday 20 November, tracks between Sherwood and Rosewood stations will be closed for maintenance and upgrade works.
Trains will return to normal on Monday 21 November.
  • removal and replacement of sleepers from Walloon to Thagoona
  • various maintenance works between Sherwood and Rosewood, including Richlands.
Affected Services:
  • Richlands line
ClintonL94
http://translink.com.au/travel-information/service-updates/bulletin/1319066150
Roma Street to Rocklea / Cannon Hill track closure
From the first train on Saturday 26 November until the last train on Sunday 27 November, tracks between Roma Street and Rocklea on the Beenleigh and Gold Coast lines, plus Roma Street and Cannon Hill on the Cleveland line, will be closed for maintenance and upgrade works.
Trains will return to normal on Monday 28 November.
  • various maintenance works between Roma Street and Rocklea, and between Roma Street and Cannon Hill.
Affected Services:
  • Beenleigh line
  • Cleveland line
  • Gold Coast line
ClintonL94
#106
http://translink.com.au/travel-information/service-updates/bulletin/1319005002
Roma Street to Rocklea track closure
From 9pm to the last train on Monday 7 November, tracks between Roma Street and Rocklea stations will be closed for maintenance and upgrade work.
Trains will return to normal on Tuesday 8 November.
  • South Brisbane station works
  • various maintenance works between Roma Street and Dutton Park.
Affected Services:
  • Beenleigh line
  • Cleveland line
  • Gold Coast line
http://translink.com.au/travel-information/service-updates/bulletin/1319007647
From 9pm to the last train on Monday 14 November, tracks between Roma Street and Rocklea stations will be closed for maintenance and upgrade work.
Trains will return to normal on Tuesday 15 November.
Affected Services:
  • Beenleigh line
  • Cleveland line
  • Gold Coast line
http://translink.com.au/travel-information/service-updates/bulletin/1319065115
From 9pm to the last train on Monday 21 November, tracks between Roma Street and Rocklea stations will be closed for maintenance and upgrade work.
Trains will return to normal on Tuesday 22 November.
Affected Services:
  • Beenleigh line
  • Cleveland line
  • Gold Coast line
EDIT: I changed the track closures from Roma Street - Dutton Park to Roma Street - Rocklea as TransLink changed the closures.
Set in train
Quote from: ClintonL94 on October 24, 2011, 23:34:30 PM
This is as clear as mud to me. Does that mean trains will begin from or the next station after Dutton Park?
If buses are replacing the whole line, say I stand at the Coopers Plains platform for the 5:45am train, where will I be directed to to board the bus?
Quote from: Set in train on October 26, 2011, 01:18:54 AM
I would think there would probably be an announcement on the train, though from the sounds of that the bus would go from Dutton Park. Perhaps give Translink a call?
Only the Cleveland line is affected.  When the line between Park Road and any point further out on the line (eg Murrarie, or the whole line) is closed, outbound trains go straight from Park Road to Dutton Park and unload/reverse there because it is operationally superior to just terminating them at Park Road.  If you are coming from Murrarie, you will be dropped off at Dutton Park to join an inbound train there.
These days, it would be superior to have the changes at Boggo Road/Park Road, but the rail bus contractors are not necessarily all qualified to use the busway.
Quote from: SurfRail on October 26, 2011, 08:34:23 AM
Indeed it would.  I haven't thought about this before.  You need to be "qualified" to use the busway?
Is it possible to use Park Rd #3 and the DG for outbound trains sort of like what the weekend Shorncliffe trains do?  I guess the approach to Park Rd #3 from the north is probably unsignalled.  I suppose it isn't a big deal to turn around at Dutton Park.
Quote from: Simon on October 26, 2011, 09:04:31 AMYou need to be "qualified" to use the busway?
Yes.  Most of the operators already are, but not all.
Robert_Dow Robert Dow
Yet another track closure Sherwood <-> Rosewood 8pm today till last train Sunday --> http://translink.com.au/travel-information/service-updates/bulletin/1319008692 @QueenslandRail
47 minutes ago
Set in train
Could someone please explain the planned closure Roma St to Rocklea - does that means trains are running from Rocklea to Varsity? What happens with Airtrain customers? I cannot find any mention of this on the TL website.
My understanding is that all trains from the Gold Coast/Beenleigh are travelling via Tennyson this weekend
http://translink.com.au/about-translink/reporting-and-publications/media-releases/release/433
QuoteTrain customers should allow up to an extra 30 minutes to travel on the Beenleigh, Gold Coast and Cleveland lines this weekend.
The Beenleigh and Gold Coast lines between Roma Street and Rocklea stations, plus the Cleveland line between Roma Street and Cannon Hill stations, will be closed on Saturday November 26 and on Sunday November 27.
TransLink spokesman Andrew Berkman said there would be changes to train services on the weekend:
Cleveland line
    Buses will replace trains, stopping all stations between Central and Cannon Hill stations. Trains will run between Cannon Hill and Cleveland, as normal.
Beenleigh line:
    Buses will replace trains, stopping all stations between Central and Rocklea stations. Trains will run express between Roma Street and Rocklea via the Tennyson loop, then as normal to Beenleigh.
Gold Coast line:
    Buses will replace trains, stopping all stations between Roma Street and Rocklea. Trains will run express between Roma Street and Rocklea via the Tennyson loop, then as normal to Varsity Lakes.
Set in train
Quote from: david on November 26, 2011, 15:38:31 PM
Cleveland line
Beenleigh line:
Gold Coast line:
Thanks David, off the home page, all I saw was this:
ClintonL94
http://translink.com.au/travel-information/service-updates/bulletin/1321332450
From 8pm Friday 2 December to the last train on Sunday 4 December, tracks between Corinda and Rosewood (including Richlands) will be closed for maintenance and upgrade works.
During this time, buses will replace trains in both directions. Remember to plan your journey well in advance and allow up to 60 minutes for travel.
Trains will return to normal on Monday 5 December.
Stations affected include:
  • various maintenance works between Corinda and Rosewood, including Richlands.
Rosewood to Helidon railbus (route 539)
Customers travelling on route 539 should allow for extra travel time (approximately 15 minutes) during this track closure.
Affected railbus services include:
  • Friday 2 December – 8.05pm
  • Saturday 3 December – 8.03am, 12.03pm, 5.01pm, and 7.03pm
  • Sunday 4 December – 8.33am, 12.06pm, and 7.06pm.
Need assistance?
Customers with a disability can call 3606 5555 or SMS 0428 774 636 or speak with station staff on the day.
Affected Services:
  • Richlands line
Quote from: Arnz on December 01, 2011, 13:29:51 PM
FIVE partial shutdowns on the Ipswich/Rosewood lines this month.
http://www.facebook.com/photo.php?fbid=313278545357179&set=a.313278038690563.84640.139321872752848&type=3&theater
A letter to the editor Queensland Times published 1 Dec 2011
Give us a break
