Last evening ...
TransLink SEQ ‏@TransLinkSEQ 8h
Trains suspended Lota-Wellington Pt due to signal failure. Buses to replace trains. 45min delays expected. #qr
http://jp.translink.com.au/travel-information/service-updates/details/1371032624
Sunshine Coast line delays
Last updated: 8.23pm Wednesday 12 June 2013
A motor vehicle has entered the rail corridor just north of Caboolture station causing delays to Sunshine Coast line trains.
The 6.59pm Roma Street to Nambour train is currently being held just north of Caboolture station while rail staff investigate.
Customers can expect delays.
http://jp.translink.com.au/travel-information/service-updates/details/1371074261
Delays due to track fault at Albion
Last updated: 8.04am Thursday 13 June 2013
Inbound trains between Northgate and city stations are delayed up to 10 minutes due to a track fault at Albion.
Quote from: ozbob on June 12, 2013, 20:33:28 PM
Couriermail --> Car travels 180m on train tracks at Caboolture after leaving level crossing
Overnight ..
TransLink SEQ ‏@TransLinkSEQ 4h
Ipswich/Rosewood trains suspended between Redbank & Bundamba due to cattle on tracks. Buses are being arranged
Outbound trains using Exhibition Loop due points failure, missing Central & Fortitude Val. Up to 20 min delays:
Overnight ..
Ipswich/Rosewood line trains suspended in both directions due to bridge strike. Delays of approx 50 mins:
http://jp.translink.com.au/travel-information/service-updates/details/1371416432
6.48am Varsity Lakes-Bowen Hills train cancelled
Last updated: 7.00am Monday 17 June 2013
The 6.48am Varsity Lakes to Bowen Hills (and Airport) train has been cancelled due to a mechanical fault.
The next inbound train departs Varsity Lakes station at 7.04am.
http://jp.translink.com.au/travel-information/service-updates/details/1371434371
Ipswich/Rosewood line delays
Last updated: 11.59am Monday 17 June 2013
Ipswich/Rosewood line trains are delayed up to 20 minutes in both directions due to a track fault at Wacol, which has closed one of two tracks.
Last updated: 12.19pm Monday 17 June 2013
As a result, the 12.26pm Central to Ipswich train will terminate at Darra station and customers on this service will be transferred by bus to Ipswich station.
Inbound trains are still running, but will experience delays of up to 20 minutes.
Quote from: ozbob on June 17, 2013, 12:31:21 PM
Shambles ....
Last updated: 12.32pm Monday 17 June 2013
As a result, the 12.26pm and the 12.56pm Central to Ipswich trains will terminate at Darra station and customers will be transferred by bus to Ipswich station.
Simply run a rail shuttle Darra <-> Goodna ...
No  it is all too FUKING hard to write out bits of paper ...
LX at Wacol can be activated manually as needed ..
TransLink SEQ ‏@TransLinkSEQ 7m
1.28pm Central-Ipswich train will also terminate at Darra. Bus will replace train to Ipswich. #qr
Yes.  They could run out of trains for the down journeys before long.
So run a shuttle between Darra <-> Goodna rail can could be done, but bus if all too hard..  Trains can turn back at Goodna there is a crossing from down to up.
Turn back at Darra.
Once fixed, there are still trains in position to resume normal timetables.  The way they are going they are going to run out of trains ...
Getting messy ...
Last updated: 2.40pm Monday 17 June 2013
Ipswich/Rosewood line trains are currently experiencing delays in both directions due to a track fault at Wacol, which has closed one of two tracks.
As a result, the 2.37pm Ipswich-Central train will now start from Darra station at 3.07pm.
Customers between Ipswich and Darra stations will experience a delay of 30 minutes until the next service departs Ipswich station.
This is the better option I think ....
Central <==> Darra <----- Wacol-----Gailes------->Goodna <==> Ipswich
                                       rail or bus shuttle
As noted above looks like they are already having problems in turning out down services ex Ipswich ... wot a surprise!
I don't get it?  If a train can get through then what is the shuttle needed for?
Quote from: Simon on June 17, 2013, 15:00:59 PM
Because they are only running down trains ...  no up trains getting through.
Hence they have (will) run out of trains at Ipswich.  So if the fault continues they will have to run bus Darra <---> Ipswich both ways ...
So if you run trains between Ipswich and Goodna as one sector you keep the trains on that sector.  Similarly Darra < -- > CBD etc.
So you can bridge the gap with a rail shuttle/bus shuttle.
Once the line re-established away you go ...
Lucky break ...   :clp:
TransLink SEQ ‏@TransLinkSEQ 1m
Ipswich/Rosewood line trains have resumed following earlier track fault @ Wacol. Residual delays of up to 20 minutes in both directions. #qr
http://jp.translink.com.au/travel-information/service-updates/details/1371446458
Beenleigh/Ferny Grove line disruptions
Last updated: 3.20pm Monday 17 June 2013
The 2.42pm Ferny Grove to Yeerongpilly train will terminate at Roma Street due to a mechanical fault. The next Beenleigh train will depart Roma Street at 3.34pm and will stop all stations to Yeerongpilly station.
As a consequence of this mechanical fault, the 4pm Yeerongpilly to Ferny Grove train will start its journey from Roma Street on schedule at 4.19pm. Customers for stations between Yeerongpilly and Roma Street can catch the 4.41pm Beenleigh to Ferny Grove train.
http://jp.translink.com.au/travel-information/service-updates/details/1371520211
Kingston track fault
Last updated: 11.57am Tuesday 18 June 2013
Trains have been delayed up to 15 minutes in both directions, due to a track fault at Kingston.
The following train services have been affected:
    10.28am Airport to Varsity Lakes
    10.48am Varsity Lakes to Airport
    11.29am Beenleigh to Ferny Grove
TransLink SEQ ‏@TransLinkSEQ 8m
The 11.30am Roma St to Nambour train has been delayed up to 10 mins due to a minor track fault at Bowen Hills. #qr
Jeff Addison ‏@Jeffrey_Addison 4m
Report just in. 5:24pm Nambour train. There is a track fault at bowen hills we are stuck at roma st not moving no trains are moving north.
Jeff Addison ‏@Jeffrey_Addison 3m
More on report just in..Frayed power lines have stopped ALL northbound trains...
Jeff Addison ‏@Jeffrey_Addison 21s
Power lines are down at bowen hills we are still at roma st they have told us that we may be able to go the back way via the exhibition
Quote from: ozbob on June 18, 2013, 17:42:27 PM
A nambour train just left towards normanby.....very packed!
Queensland Rail ‏@QueenslandRail 2m
.@4020Nick there has been damage to overhead line at Bowen Hills. Repair crews arriving shortly. N/bound trains up to 15mins delay.
Quote from: ozbob on June 18, 2013, 17:46:46 PM
Nothing from TransLink yet ...
Jebus, they really do hate the Sunny Coasters ...   :P :P :-* :-*
http://jp.translink.com.au/travel-information/service-updates/details/1371541604
Train delays: Northbound services
Last updated: 5.51pm Tuesday 18 June 2013
Trains heading northbound through the Brisbane CBD are currently delayed up to 15 minutes due to do a fault with an overhead power line at Bowen Hills. Platform 4 at Bowen Hills station is not in use.
As a result of this delay, the 5:22pm train service from Central to Caboolture station has been cancelled. Passengers can catch the next available service from Central station.
Please use the journey planner to find alternative transport.
We apologise for the delay.
Affected services:
    Airport
    Gold Coast
    Beenleigh
    Ferny Grove
    Shorncliffe
    Cleveland
    Doomben
    Caboolture
    Sunshine Coast
    Ipswich/Rosewood
    Richlands
Queensland Rail ‏@QueenslandRail 1m
Repair crews are on site fixing the fault at Bowen Hills. We will advise as soonas the overhead line is repaired. Our apologies for delay.
Mozz
Stuck at milton atm told that train has broken down between central and roma street...
At last ...
Ongoing delays up to 15 mins for trains heading thru Bowen Hills station due overhead power issue. http://bit.ly/11VZ5Ci  #qr
TransLink had a 'twitter fault' ...   :bg:
TransLink SEQ ‏@TransLinkSEQ 2m
Apologies, our Twitter feed was temporarily down. We are now back online. Delays continue for outbound trains through Bowen Hills. #qr
Quote from: ozbob on June 17, 2013, 12:52:32 PM
You can't turnback trains at Goodna, nearest turnback location is Redbank.
Sunlander/Queenslander stuck on platform 4 at Bowen Hills. Returning empties lined up between Bowen Hills and Woolloowin.
Quote from: Derwan on June 18, 2013, 19:06:54 PM
Im currently on spirit of outback? Been delayed for about 40 mins so far. Delayed due to staff injury.
Now been delayed 2.5 hours.
Im going to assume since this is a serious safety incident that it will be investigated a lot more beyond tonight.
A lot of the staff seem to be distressed atm and are keeping quiet.
We should be off soon all going well :bo
Quote from: STB on June 18, 2013, 18:49:58 PM
Really?  There's points in both directions between Goodna and Redbank, and only in one direction between Redbank and Riverview.  There must be a dark (unsignalled) area, if that's true.
