16th December 2019
Targeted public transport improvements --- here are the targets!Good Morning,
From July 2019 TransLink moved to the new Customer Experience Survey (
https://translink.com.au/about-translink/reports-and-publications ), integrating the monthly performance snapshots and replacing the former quarterly TransLink Tracker with the new TransLink PT Performance Dashboard. A move which we welcome, as more robust survey data is obtained and published, and hopefully in a more timely manner than before.
TransLink has stated that one of the reasons for moving to the new research survey methodology is
" ... The customer understanding gained from this research will be used to drive targeted public transport improvements, and to help ensure the public transport experience is meeting customer needs .." a laudable aim.
Analysis of the customer experience survey data for July 2019 to October 2019 has already indicated clearly where targeted public transport improvements should be directed. Using the ' Customer experience ' survey data provided at
https://www.data.qld.gov.au/dataset/translink-monthly-performance-data/resource/c1984b8b-3822-41b0-bf90-b18b4a930072 the worst performing categories can be identified, viz., Cost of trip, Frequency of services, and Ease of transferring.
1.
Passengers rate fare affordability as particularly poor for rail and bus. One way of addressing this would be to offer additional periodical ticketing options on the new smart ticketing system. In our recent 2019 Public transport passenger survey we asked a supplementary question re ticketing:
" TransLink is going to introduce a new fare system Queensland wide.
Would you like see see additional optional ticketing products such as
periodical ticketing (e.g.) weekly, monthly, yearly options made available? "79.8% of the respondents answered yes to this question. Clearly there is strong support for these additional optional ticketing products.
2.
Bus and rail service frequency needs improvement. Without adequate frequency a public transport network is difficult to use, and makes connections/transfers more difficult. Frequency of bus is good in Brisbane with busway and BUZ routes, but most other routes in Brisbane and the other SEQ bus regions are very poor. Rail frequency, counter-peak and off-peak needs significant improvement.
3.
Connections, and transferring make a public transport work overall. Rail/bus, rail/rail, bus/bus transfers often are difficult due to poor transferring facilities and a mismatch in timetables. TransLink need to focus on improving timetables such that more reliable running for bus particularly is made and connections are better facilitated over the entire network.
From January 2020 we would like to see TransLink to start to address these identified issues with priority. Government needs to properly support TransLink in terms of funding for service improvements and resources.
RAIL Back On Track
https://backontrack.org
