Eastern Busway...questions.
Started by Gazza, April 01, 2013, 02:00:49 AM
So I'm just browsing the Eastern Busway drawings..... http://translink.com.au/about-translink/what-we-do/infrastructure-projects/eastern-busway/maps
Few things have me thinking:
1)
http://translink.com.au/resources/about-translink/what-we-do/infrastructure-projects/eastern-busway/100420-drawing-4.pdf
http://translink.com.au/resources/about-translink/what-we-do/infrastructure-projects/eastern-busway/100420-drawing-5.pdf
The Carina busway station and section should be the first bit done because it's so easy. All in the tram median, and no bridging works needed.
2)
Carindales section is probably the next best thing, the revised design is pretty good:
http://translink.com.au/resources/about-translink/what-we-do/infrastructure-projects/eastern-busway/100420-drawing-13.pdf
http://translink.com.au/resources/about-translink/what-we-do/infrastructure-projects/eastern-busway/100420-drawing-14.pdf
3) http://translink.com.au/resources/about-translink/what-we-do/infrastructure-projects/eastern-busway/100420-drawing-6.pdf
http://translink.com.au/resources/about-translink/what-we-do/infrastructure-projects/eastern-busway/100420-drawing-7.pdf
East of Carindale at Belmont, why is the busway a long driven tunnel?
It is a pretty wide road:
http://goo.gl/maps/Ck5Qf
Could it not be a median busway, with dives under the intersections?
And if its just a state owned primary school, upgrading a few buildings on site and making use of the land has gotta be cheaper right?
4) http://translink.com.au/resources/about-translink/what-we-do/infrastructure-projects/eastern-busway/100420-drawing-9.pdf
Around the sleeman Center, is the design as simple as it could be.
5)
http://translink.com.au/resources/about-translink/what-we-do/infrastructure-projects/eastern-busway/100420-drawing-2.pdf
http://translink.com.au/resources/about-translink/what-we-do/infrastructure-projects/eastern-busway/100420-drawing-3.pdf
Ugh expensive, do these sections last.
barnesy
Cmap Hill section is going to be most annoying bit
