Links
Author Topic: Canberra - Sydney Electrification  (Read 1466 times)
Offline verbatim9
« on: December 02, 2015, 06:08:14 PM »
Councils support Sydney Canberra electrification
http://m.brisbanetimes.com.au/act-news/councils-support-electrification-of-canberra-to-sydney-rail-line-20151201-gld11i.html?utm_source=twitterfeed&utm_medium=twitter
Offline verbatim9
Re: Canberra - Sydney Electrification
« Reply #1 on: December 02, 2015, 06:11:54 PM »
I am all for that and if HSR ever comes into play they can revert the existing line  and use it as electrified freight and commuter mix
P.s Wander if it will be 25Kv AC or 1500v DC system. The newer Sydney trains are dual voltage apparently in a proposed mootted move to 25kv Ac!?
« Last Edit: December 02, 2015, 06:24:42 PM by verbatim9 »
Offline MaxHeadway
    • My Behance account (Some transit map attempts)
« Reply #2 on: December 02, 2015, 10:22:23 PM »
What's the use when the trains dump you out in Kingston?
"Good design is as little design as possible."
—Dieter Rams
Offline verbatim9
« Reply #3 on: December 02, 2015, 11:41:15 PM »
They might make modifications on the Canberra side? To the Airport or closer to Civic? Connect with a light rail station interchange. Things can be modified. Where there is a will there is a way :)
Sitemap 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24
