Queensland UTC +10
Links
Author Topic: Indooroopilly Station Upgrade - platforms 3 and 4 updates  (Read 4682 times)
Offline ozbob
« on: June 18, 2008, 04:49:29 PM »
Some photographs showing the progress with platforms 3 and 4 Indooroopilly as at 18 June 2008.
For earlier works including platforms 1 and 2 see --> http://backontrack.org/mbs/index.php?topic=300.0
Photographs R Dow 18 June 2008
« Last Edit: August 19, 2008, 07:55:58 PM by ozbob »
Offline david
Re: Indooroopilly Station Upgrade - platforms 3 and 4 updates
« Reply #1 on: June 20, 2008, 10:50:59 AM »
Just one question bothering me...
The staircase on Platform 3/4 seems to be quite wide. How will passengers disembarking behind the staircase be able to access it safely without crossing over the yellow safety line? Also, how will wheelchair users be able to get to the centre of the platform if the staircase is blocking the pathway towards the lift? Are they planning to widen the platform?
Offline ozbob
« Reply #2 on: June 20, 2008, 10:57:25 AM »
I had a good look at it.  The stairs seem offset towards platform 4. This leaves room on the platform 3 side for a wheelchair.
I agree though it is tight.  As far as I am aware there is no plan to widen the platform.  If anyone knows any more please let us know.
The access on the platform 4 side against the stairs will be blocked, this is similar to a platform at Corinda (1 from memory?).
Regards
Bob
« Last Edit: June 20, 2008, 11:01:51 AM by ozbob »
Offline Derwan
  • Now a bus person
    • Andrew's Place
« Reply #3 on: June 20, 2008, 01:38:55 PM »
I heard that around school-finishing time, the platforms are packed with school children.  Perhaps widening the platform would be a good idea.
Offline ozbob
« Reply #4 on: June 20, 2008, 03:35:53 PM »
Yes, using platforms 3 and 4 it was tight, but manageable.
Now that platforms 1 and 2 back in use no real issues other than normal platform usage problems.
They had speed restrictions during the peaks for platforms 3 and 4, but no longer as back on the up and down suburban lines.
It might be difficult to widen the platform as there is not much room.
Offline ButFli
« Reply #5 on: June 23, 2008, 10:18:13 AM »
It is not possible to simply "widen the platform". The main line would have to be shifted. To do that they'd have to widen the "cutting" which would mean they'd have to remove part of Coonan Street. Not going to happen.
Platform 3/4 at Indooro is only used for the occasional express service. It's no narrower than any of the other platforms servicing the main line. If the stairs are that much of a concern they could close the section of platform behind them which would only make the front door of the front car unusable.
Offline ozbob
« Reply #6 on: August 19, 2008, 05:50:23 PM »
Some progress photographs 19 August 2008
Platforms 1 and 2
Photographs R Dow 19 August 2008
« Last Edit: August 19, 2008, 05:52:00 PM by ozbob »
Offline mufreight
« Reply #7 on: August 19, 2008, 06:21:40 PM »
Pity that they did not raise the platforms while they were at it but it would seem to be in keeping with other works that have been carried out of late which would appear to be intended by gouernment to be seen to be doing something but unfortunately fall short of the bar and tend to discourage rather than attract commuters by making their facilities more user friendly and safer, which raises the question, WHY?
« Last Edit: August 20, 2008, 11:30:29 AM by mufreight »
Offline ButFli
« Reply #8 on: August 20, 2008, 12:57:46 PM »
Platforms 3 & 4 cannot be raised and still allow diesel locos through. Freight is the line's primary purpose.
Offline mufreight
« Reply #9 on: August 20, 2008, 06:43:55 PM »
That diesel locos use the line is no reason not to raise the platform levels, by moving the coping back and then raising the platform level it is quite simple, if you have a look at the raised section at Brunswick Street you will note that running clearance has been maintained by moving the coping back on the raised section, a 100mm gap is preferable to and safer than a 450mm + step up with a correspondingly larger gap under the step.
At floor level an EMU is the same width as the maximum dimension locos 28, 40, 41 & PN classes.
Next.
Offline ButFli
« Reply #10 on: August 21, 2008, 08:39:27 AM »
It seems platforms 3 and 4 are being raised. The coping on the platform 4 side is anyway. I got a warm fuzzy feeling in my tummy when I arrived at the station this morning to observe two blokes laying what look like concrete pavers onto the existing coping. I'm retarded.
Although to be fair the 60mm increase in height is trivial.
Offline ozbob
« Reply #11 on: September 21, 2008, 05:23:17 AM »
Couple of recent photographs:
Photographs mufreight September 2008
Offline ozbob
« Reply #12 on: October 03, 2008, 04:49:43 PM »
Called in on the way home this afternoon and had a quick look around.
Some photographs.
General overview
Platform 3 and 4
Stairs platform 1 and 2
Looking in an up direction at the Concourse on top of platform 1 and 2
Photographs R  Dow 3 October 2008
Offline ozbob
« Reply #13 on: October 11, 2008, 10:20:10 AM »
Platforms 3 and 4 are open this weekend at Indooroopilly, 11-12 Oct 2008.
Although this photograph of an up Ipswich service at Indooroopilly platform 3 suggests the station is not yet ready. Indeed, a lot of work is still to be done but everything was well fenced off and there are no real issues.  Work is proceeding around platform 1 and 2 this weekend.
Photograph R Dow 11 October 2008
« Last Edit: October 11, 2008, 05:36:53 PM by ozbob »
Offline ozbob
« Reply #14 on: October 25, 2008, 08:00:38 PM »
Extensive murals of a seascape type of scene are presently being painted on the walls opposite platform 4.
I get a bit sea sick these days at Indooroopilly ...   :-r
Still it is nice and bright in terms of colours, and very different for a railway station!
 :-t
Offline ozbob
« Reply #15 on: October 31, 2008, 05:56:32 PM »
See this thread for a special update!
--> http://backontrack.org/mbs/index.php?topic=1473.0
 :-t
